C -1 '61 with dual carbs idling issues - NCRS Discussion Boards
  • Mike B.
    • August 14, 2011
    • 61
    Re: C -1 '61 with dual carbs idling issues
    Thanks to all. Funny you mention the vacuum pulsation. In trying to adjust carbs with vacuum guage I cant due to rapid needle oscillation between 9 and 13 at idle which means I have other issues I am sure. Only able to adjust with the screws for the time being. About the stripped screws I was hoping that I could just tap like you suggested. Thanks.
    • Clem Z.
      • January 1, 2006
      • 9427
      when using longer screws i have found i had to cut the screws to a length i could use because some of the holes bottom out
