1961-1962 vette Mirror Judging Question on mirror glass gap vs no gap? - NCRS Discussion Boards
  • Gary C.
    Administrator
    • October 1, 1982
    • 17773
    Re: 1961-1962 vette Mirror Judging Question on mirror glass gap vs no gap?
    Mark,
    Knew there was the possibility that early '61's could have 60 style mirror glass. Didn't know it went that late.
    Heitzman's the Team Leader and it's his call. Am curious if you asked how that was determined?
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Dennis C.
      • June 30, 2002
      • 884
      I would proceed with caution if making a change before you see what is actually written in the revised guide.
      Dennis
      • Mark S.
        • July 31, 1983
        • 664
        #18
        Gary: This is the reply that I received from Dave Heitzman for a clarification: "Early and mid 1961 INTERIOR mirror glass may be the same as all 1953-60 mirror glass, which is dark and silvered on the backside, creating the gap in the reflection. At some point during early 1961 the lighter shaded glass without a reflection gap started to replace the darker glass that had a gap. The earliest no-gap glass that I have documented is 1961 VIN 04527, although use could have began earlier. The one-owner 1961, VIN 06527, has the darker glass and gap. Based on this your 1961 VIN 06533 could have had either type glass in the interior mirror. There is no evidence of a certyain date that one glass type ended and the other began. As with many changeovers the new and old parts were intermingled for a period of time. Sometime between late 1960 and early 1961 the EXTERIOR mirror glass changed from the dark glass with a gap to lighter shading with the silvering applied on the front side, which eliminated the gap in the reflection. During early 1961 either type glass was possible. Your later 1961 VIN 06533 would have had the lighter glass and no gap. For 1962 both interior and exterior mirrors used the lighter shading and do not have the gap. I apologize for not researching your question more adequately before giving you the first answer."
        • Gary C.
          Administrator
          • October 1, 1982
          • 17773
          #19
          Mark,
          Thanks for posting Dave Hetizman's response. Knew it was possible for early 61, but didn't know the interior mirror change over carried into mid year.
          Dave's correct about hard to pin down production use change over dates. As an example there are several known last 50 VIN 57's that have both 56 and 58 parts on them. The 56 style parts were from cleaning out the bottom of the bins on parts that weren't used in 58.
          Gary
          NCRS Texas Chapter
          • John F.
            • March 23, 2008
            • 2415
            #20
            Using the pencil point both of my 62s, interior & exterior mirrors, the points touch. Cars #00029 & #10975 if that helps.
            • Gary C.
              Administrator
              • October 1, 1982
              • 17773
              #21
              John,
              No contest on 62's interior/exterior mirrors.
              Pencil point test can sometimes be viewed wrong. Always best to use a credit or business card held perpendicular to the mirror and position your viewing angle half way between the mirror glass and card (45 degrees).
              JMTCW,
              Gary
              NCRS Texas Chapter
              • John F.
                • March 23, 2008
                • 2415
                #22
                No gap with credt card on either one-just checked.
                • Mark S.
                  • July 31, 1983
                  • 664
                  #23
                  Gary:
                  You are very welcome! I have a late 56, Vin 4200; which has several 57 parts on it, so I am aware of the change-overs that the plant went through.
                  Sincerely,
                  Mark
                  • Gary C.
                    Administrator
                    • October 1, 1982
                    • 17773
                    #24
                    Mark,
                    Thanks for letting me know about your late '56. Couple of questions on your '546:
                    1) does it have a '57 rear spring (front) hangars
                    2) was the original stencil readable, if so what was the part number and date
                    Appreciate the info.
                    Gary
                    NCRS Texas Chapter
                    • Mark S.
                      • July 31, 1983
                      • 664
                      #25
                      Gary:
                      I can answer question 2. right away. The original stencil was not readable. The 56 has 59,000 original miles on it and I can trace all the information back to 1958. Jim Frakes and I compare a lot of notes , because he is the original owner of a late 56.
                      Sincerely,
                      Mark
                      • Gary C.
                        Administrator
                        • October 1, 1982
                        • 17773
                        #26
                        Mark,
                        Know Jim Frakes very well. Had the opportunity to Judge with and get to know Jim well in the 90's. True gentleman who has willingly shared his '56 knowledge with lots of us.
                        Let me know about the frame front spring hanger style. Thanks,
                        Gary
                        NCRS Texas Chapter
                        • Vinnie P.
                          Editor NCRS Restorer Magazine
                          • May 31, 1990
                          • 1575
                          #27
                          Hi Mark...is there something I'm missing here...in one sentence, Dave Heitzman says "The one-owner 1961, VIN 06527, has the darker glass and gap. Based on this your 1961 VIN 06533 could have had either type glass in the interior mirror."
                          And the third sentence from the end says "Your later 1961 VIN 06533 would have had the lighter glass and no gap."...so earlier he says your car could have either and then later he says your car, which is only 6 cars after the one cited should be different?
                          I think I would ask for a clarification, appears confusing to me.
                          Vinnie
                          • Mark S.
                            • July 31, 1983
                            • 664
                            #28
                            Gary:
                            I had to go check my 56 to be sure. My original frame front spring hanger is of the 57 style. You may also be aware of my C1 spring article in the Restorer.
                            Sincerely,
                            Mark
                            • Mark S.
                              • July 31, 1983
                              • 664
                              #29
                              Vinnie:
                              The first paragraph refers to 61 Interior mirrors and the next paragraph refers to 61 Exterior mirrors. Sorry for the confusion.
                              Sincerely,
                              Mark
                              • Gary C.
                                Administrator
                                • October 1, 1982
                                • 17773
                                #30
                                Mark,
                                Recall reading an article you wrote 5 years or so ago about C1 springs with Julian date photos.
                                Your '56 frame stencil would've been 303190-40 with a mid June date. 4026 stencil date was 6/12/56.
                                Gary
                                NCRS Texas Chapter
