1960 Ignition Shielding - NCRS Discussion Boards
  • Thomas H.
    • August 31, 2005
    • 1068
    Installing the ignition shielding on my 60. The AIM shows a spacer being used on the pass side rear bracket. Anyone know how thick it is?
    Tom
    2007 Z06, Lemans Blue
  • Philip P.
    • February 28, 2011
    • 558
    Re: 1960 Ignition Shielding
    Tom, If I am not mistaken that "spacer" is actually the flat washer used with the exhaust manifold bolts. It is placed next to the manifold then the "L" bracket, the french lock and then the bolt. Its job is to keep the bolt from tearing up the manifold when tightened. washer is about 1/8" thick
    Phil
