1970 Convertible Upper Windshield Molding - NCRS Discussion Boards
  • Terry B.
    • April 1, 2003
    • 50
    Does anyone know if the Upper Windshield Molding (Not the flat stainless piece on top, but the the one that goes along the top of the windshield) requires sealer when installed or is it held in place just with the clips attached to the upper windshield frame? Thanks Terry
    Web Master Miami Valley Chapter 2010 to present
    Newsletter Chairman Miami Valley Chapter 2003 to 2011
    Events Chairman Miami Valley Chapter 2010
    Miami Valley Chapter Secretary 2012 to 2015
    Miami Valley Chapter Media Chairman 2016
    Miami Valley Chapter Judging Chairman 2017 to present
    • 15616
    Re: 1970 Convertible Upper Windshield Molding
    I am not sure about "requiring" sealer, but every one I have seen, even those that were new in 1970, had sealer. Maybe they all leaked without it.
    Take a look in the AIM. If sealer is "required" you will see a note with a numbered drop shaped symbol by the molding. Look up the number int he front of the AIM and it will tell you the GM part number (not that that will do you any good) for the sealant and sometimes the supplier, not that that will do you any good either.
      • 43248
      Terry------
      Yes, rarely, if ever, were GM adhesive and lubricant products used in PRODUCTION ever available in SERVICE, at least under the part numbers shown in the AIM. This is because the part numbers shown are for the products supplied in bulk or giant-sized unit quantities to the assembly plant. In some case, the product was available in SERVICE but under a different part number for a consumer-size quantity.
      • Terry B.
        • April 1, 2003
        • 50
        Thanks Terry. I'll take another look at the AIM manual, last time I looked, it wasn't all that clear.
