Pulsating Throttle on 56 WCFB - NCRS Discussion Boards
  • Mark P.
    • July 31, 2003
    • 407
    Just started my 56 dual quad for the first time since a total engine and carb rebuild and the metering rods on the primary carburetor are pulsing up and down and the engine revs at 2 second intervals rather than iding smoothly. Is that a jet placement issue or a power valve spring issue? Any thoughts would be appreciated!
    Mark
    Mark Pugmire
    54 Pennant Blue
    56 Cascade Green Dual Quad
    56 Arctic Blue Dual Quad
    66 Nassau Blue 427 L36 Convertible
    67 Marlboro Maroon L79 Coupe
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Pulsating Throttle on 56 WCFB
    Mark
    try it without a power piston spring and see if that fixes the idle problem. if it does then find a spring that stops the pulsing by allowing the piston to stay down at idle
    • Mark P.
      • July 31, 2003
      • 407
      Thanks for the response, Clem. So is the spring potentially too weak? Is that what's allowing it to drop?
      Mark Pugmire
      54 Pennant Blue
      • Clem Z.
        • January 1, 2006
        • 9427
        at idle the vacuum should over come the spring tension and keep the power piston at the bottom of the chamber so the metering rods have the larger diameter in the jets,lean stop. you either have not enought vacuum at idle or too strong a spring. check your timing and valve lash as this effects the vacuum at idle
