I just rebuilt my 59 283-230 engine and it seems to run fine. The problem is that antifreeze keeps coming out from the rad cap. I had the rad checked before installing it and have tried 3 different rad caps at 7#. I have the correct Harrison Copper rad. I thought this was the normal as "it will find its own level", but after a 150 miles it should have settled by now. I'm running a 160 degree Thermostat and a 50-50 mix of Peak antifreeze. So far the temp gauge has climbed to approx 190 degrees in traffic but normally runs at about 170. Any suggestions?
