The letter/number sequence D S - B - 5 are stamped into the support behind my trim tag. Any help on their meaning?
Numbers behind the trim tag
Re: Numbers behind the trim tag
Ammon -
All A.O. Smith bodies had a date code stamped on that reinforcement, which was hidden later by the trim tag; what's the body build date code embossed above "STYLE"?- Top
JR -
That was only the case in 1964, when A.O. Smith body production started (in January) - in '64, an "A" on an A.O. Smith tag was January, and an "A" on a St. Louis tag was September. In '65 and '67, A.O. Smith and St. Louis used the same letter/month coding (A = August), but it was different in '66 - "A" was August on A.O. Smith tags, and September on St. Louis tags.- Top
John,
So Dow used the model year for 65 in the 64 calender year in this case?
Or, would this stamp actually indicate it was actually the calender year date, which would not make sense being a Sept build date for a 65 model year car? I would expect to see DS-B-4 ?- Top
Bill -John,
I've only seen one A.O. Smith body with the trim tag removed so the date was visible before Ammon mentioned his, and that was many years ago; based on his observation, I'm guessing that they used the model year in their internal date code, not the calendar year. I don't think many folks are willing to remove their trim tag to do any further research on the issue.
