Oil filler tube with screw on cap - NCRS Discussion Boards
  • Jerry G.
    • April 1, 1985
    • 1022
    I am having problems with pressure build up in the crankcase on my vintage road race motor. Its a Fuel injected(Rochester) motor. I think the problem comes from prolonged RPMs over 6500. I don't plan to change that but I do need an oil filler tube for the front of the intake adaptor that has a real screw on cap. The stock one for a 65FI car works itself off and needs to be retained with a tension spring. It's a new cap and tube so it's not worn. I don't car if its stock or not just that I can screw it on and keep it from working loose. Any suggestions?? In a related problem the dip stick also pops out of it's tube ( not all the way) and looses the seal and blows oil around. It is also retained with a spring. Any clever ideas on this one? Jerry
  • Cecil L.
    • May 31, 1980
    • 449
    Re: Oil filler tube with screw on cap
    What do you have for a crankcase breather system?
    • Clem Z.
      • January 1, 2006
      • 9427
      something like this should work. http://www.grainger.com/Grainger/SHA...ion-Plug-6VFR3
      • Jerry G.
        • April 1, 1985
        • 1022
        Two AN-12 lines running from the valve cover tops to a vented collector.
        • Jerry G.
          • April 1, 1985
          • 1022
          Thanks Clem, that ought to stop it up
