Fastener 9417378 - NCRS Discussion Boards
Fastener 9417378
  • George J.
    • March 1, 1999
    • 775
    Fastener 9417378
    In the '65 AIM, this fastener is shown for attaching the steering column bracket and for the fresh air vent pulls, under the dash. I think the Judging Manual calls out a different fastener for the column bracket than for the pulls. I searched the archives, but did not see a definitive answer. Can someone tell me what the details for this fastener are, and possibly provide a photo?
    I ordered a set from LIC or Paragon and received a screw that appears to coincide with what the Judging Manual calls for, but it is like a sheet metal screw, and this does not seem right, to me for this application.
    George
  • Alan D.
    • January 1, 2005
    • 2053
    Re: Fastener 9417378
    George, do a search on that pn in the Archive Forum. Some good facts
    • Scott S.
      • September 11, 2009
      • 1961
      George,
      This same screw part number (GM 9417378) attaches the steering column escutcheon on Section 9, Sheet 5 (1963-64 AIM), UPC 9-5 (1965 AIM), UPC 9-A5 (1966 AIM). Page 9-A5 is missing from the '67 AIM, but I think the same Screw was used in '67 for this same application. My car is a '67, Screw part number GM 9417378 was also used to attach the Hood Release to the dash in 1967 (UPC 11-13-B5), and they are identical to my '67 steering column escutcheon screws.
      Mine are Phillips oval head, black phosphate (more of a dark brown, like the five main dash-cluster screws) with a flat tip, cut vertically at the tip (Type BT tip). They measure #10-16 x 5/8". The head is approximately 5/16" OD, which I think corresponds to a #8 head.
      The 65JG says:
      "The escutcheon plate is secured to the cluster by two black phosphate Phillips screws." (p. 41)
      "The fresh air pulls are located on each side of the steering column. The black plastic knobs are attached to semigloss black cast brackets, secured to the bottom edge of the instrument cluster with black phosphate countersunk Phillips screws." (p. 39) (65 AIM, 1ASM-D8)
      I believe these two quotes are describing the same screw, the first quote just doesn’t specify “countersunk” and neither mentions that it is an oval head screw.
      • George J.
        • March 1, 1999
        • 775
        Alan,
        I did do a search and only came up with two posts, neither of which had definitive information. If I'm missing something, I apologize, but could use a picture, and a description of the part no. from something official.
        George
        • George J.
          • March 1, 1999
          • 775
          Scott,
          that type of screw seems like an odd size for that application. It reminds me of the trim screws used in the rest of the interior, but for this application I would have expected a tighter thread.
          George
          • Scott S.
            • 1961
            George
            George,
            Unfortunately, this is one of the many fasteners that is not listed in any of the P&As or Standard Parts Catalogs.
            • Scott S.
              • 1961
              However, on a hunch, I jumped in the way-back machine, and in the October 1962 printing of the 1963 P&A there is an illustration titled "1963 Corvette Steering Wheel and Horn". It shows the Escutcheon (Gr. 9.746) and the attaching Screws (Gr. 8.977), which are not called out by part number, but their dimensions are given: 10-16 x 5/8"
              As mentioned previously, this same Screw (GM 9417378) is called out at this location in every AIM from 1963-1966 (page is missing from '67 AIM), which means this 1963 drawing is applicable.
              I think that is game, set and match, as far as official GM documentation goes. The only hand that could beat it is the GM Engineering Standards Book, and I don't have that one (yet)
              • Ron G.
                • December 1, 1984
                • 866
                George,
                I have some NOS hardware. I will check and see if I have any and let you know.
                - Ron
                "SOLID LIFTERS MATTER"
                • Scott S.
                  • 1961
                  Pictures of the Screws that were attached to the bottom of my '67 dash cluster, they are #10-16 x 5/8" Phillips oval head:
                  • George J.
                    • March 1, 1999
                    • 775
                    Scott,
                    That is just the type of info. I was looking for. Thank you loads!
                    Forgive my ignorance, yet again, but what does the "A" stand for in P&A? I assume the "P" is for Parts. Is it Assessories?
                    Ron,
                    Thank you, as well.
                    George
                    • Scott S.
                      • 1961
                      George,
                      Yes, P&A is Parts & Accessories.
                      Glad to be able to help,
                      Scott
                      • George J.
                        • March 1, 1999
                        • 775
                        Scott,
                        Would one of these for '65's come up on ebay, or do you know where else I could find one? Thanks again.
                        George
                        • Scott S.
                          • 1961
                          Scott,
                          George
                          George,
                          In my experience, not many of the people who sell original screws & bolts on eBay list the part number... it's more like a game where they just tell you what they think it's for, and you have to figure out whether they're right before the clock stops or someone else beats you to it
                          If it's a NOS part still in the original GM package, or still has the GM picking tag, then you can get the part number, but most of the time you're lucky if they even correctly list the dimensions (e.g., #10-16 x 5/8"). You might try Richard Fortier, he advertises in Driveline, if Ron (post #8 above) doesn't have any.
                            • 43272
                            Originally posted by Ron Goduti (8076)
                            George,
                            - Ron
                            Ron-----
                            I don't think you'll have this one unless you got them out of an assembly plant. GM #9417378 was never available in SERVICE.
                            • Ron G.
                              • December 1, 1984
                              • 866
                              Joe,
                              You're probably right, but I will let you know in the next couple of days.
                              - Ron
