1954 Motor Mount Bolt Torque - NCRS Discussion Boards
  • John L.
    • February 1, 2005
    • 207
    Real quick question which I have had difficulty in finding the answer .... installing the engine in my 54' frame and tightening up the motor mount bolt - what is the targeted torque for the mounting bolt? I was somewhere around 45 ft. lb. to get the cotter pin to align with the slotted nut. Is this sufficent??
    Thanks!!!
    John Lanning
  • Chris S.
    • January 1, 2000
    • 1067
    Re: 1954 Motor Mount Bolt Torque
    Some 54's use a "special" nut instead of castle nut
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • John L.
      • February 1, 2005
      • 207
      Thanks Chris for the suggestion of a "special" nut but not sure what that would be....I am sure it is not like the special motor mounts that bubby cut, welded, patched on my car origionally. A real piece of artwork I am saving as a conversation piece. Ha.
      John Lanning
      • Chris S.
        • January 1, 2000
        • 1067
        I hear you
        mine had been converted by Bubba with a "Hurst" V8 conversion kit
        It is an alum adapter that bolts to the front of the block
        I still have it - pretty cool......
        The nut is a "dimped" lock nut
        C Central and Paragon sells them with the correct WB bolt and washers.
