Coil Support Bracket Bolts on '69 L36 - NCRS Discussion Boards
  • Floyd B.
    • November 1, 2002
    • 1050
    These are the bolts currently securing the coil support bracket to my intake manifold. '69 L36 w/ standard ignition. Are they correct?
    Thanx
    "Drive it like you stole it"
    • 43258
    Re: Coil Support Bracket Bolts on '69 L36
    [ATTACH=CONFIG]39885[/ATTACH][ATTACH=CONFIG]39886[/ATTACH]
    Thanx
    Floyd------
    Even though they have slightly different headmarkings, I feel very confident that they are original. The GM 275M material grade is generally quite unusual but consistent with the bolts originally used for this application. Plus, the "E" manufacturer's ID is the most common for this application.
    • Floyd B.
      • November 1, 2002
      • 1050
      Thanx Joe. I FINNALY found something original on this intake manifold!
