For years I have been using a Battery Minder to keep my older (lead/acid) Restoration battery charged on my '69. It is used whenever the car is parked in the garage, 12 months a year. The leads have always been attached to the battery with the "alligator" clips supplied with the unit and the lead is fed under the headrest and through the clip that guides the shoulder belt since with the spring ring cables you can't permanently affix the leads to the battery posts. When I park the car I simply plug this lead into the lead coming from the part plugged into the wallplug. I also have a battery disconnect in use. The problem with this arrangement is that the battery compartment door has to be left open and it flops around while driving. My question is- can I use a cigaret lighter adapter to connect to the charger? Is there any danger that the wiring from the lighter might overheat or something? Thanks for your advise!
Jeff
Jeff
