Bubba moment,"Where do these go?" - NCRS Discussion Boards
  • Henry S.
    • April 30, 2005
    • 816
    The last few weeks I have been doing some work/maintenance on the 67. One of the areas I am working on is the chassis, cleaning some of the hardware and fasteners. Since this project has been going on for a few weeks I have got everything back in it's place with the exception of the ones pictures below. For the life of me I can't remember where the *#%# they go!! I know I am going to feel like a goofball when someone posts their position. Thanks for the info. Shooter
  • William C.
    • May 31, 1975
    • 6037
    Re: Bubba moment,"Where do these go?"
    Look like body mount shims.
    Bill Clupper #618
    • Henry S.
      • April 30, 2005
      • 816
      A hah....................Bill could they be the shims used at the very front of the frame the radiator support bolts into?
      • William C.
        • May 31, 1975
        • 6037
        Sure look like those could be...
        Bill Clupper #618
        • Michael G.
          • January 1, 1997
          • 1251
          Many times these are welded to the frame at the radiator support.
            Henry -
            That particular shim was used in three locations:
            1. Radiator support to frame mount (they were usually welded in place, but not always).
            2. Between the bottom of the #1 body mount bracket riveted to the dash and the top surface of the steel birdcage sill; A.I.M. UPC 1-Asm, sheets G1 & G3, item #2.
            3. Between the front of the RH seat track and the floor to level the seat; A.I.M. UPC 1-Seats, sheet J5, item #13.
            • Henry S.
              • April 30, 2005
              • 816
              Thanks for the responses. Since I was cleaning up the front chassis I'm sure when I head over to the shop tomorrow the shims between the radiator support and frame will be MIA.
