The oil pressure gauge on myn newly aquired 1969 427-390 coupe reads faulty and is it just a matter of the gauge needing to be replaced or another issue? The pressure needle shows 35 lbs without the car running and when running pegs out at the 70 lb maximum reading.
Is the replacement of the gauge a straight forward procedure of removing the center cluster, any C3 tips for removal is appreciated.
On another separate question unrelated, is there a way to distinguish P02 corvette hub caps from similar passenger car hub caps of that era or are they one in the same.
Thank you for your insight.
Gary
Gary
