RC 26 Radiator Cap - NCRS Discussion Boards
RC 26 Radiator Cap
  • Michael H.
    • January 29, 2008
    • 7477
    #31
    Re: RC 26 Radiator Cap
    Oop,s, you're right. I wasn't paying attention. Again.
    • Don L.
      • August 31, 2005
      • 1005
      #32
      Message back to Ralph: Not sure how much money your RC-26 cap is worth, but obviously, it's worth a lot of good discussion and learning here. More's going to be known as a result of your question. Thanks so much for posting! Keep 'em coming!!
      Don Lowe
      NCRS #44382
      Carolinas Chapter
      • Dick W.
        • 10483
        #33
        Good to know that I ain't the only one a gitt'n old..
        Dick Whittington
        • Michael H.
          • January 29, 2008
          • 7477
          #34
          Brain fade, uncle Dick. Happens more frequently now.
          • Jeff A.
            • January 1, 2000
            • 312
            #35
            $250+ for a nice RC26
            My Cars
            • Ralph S.
              • February 1, 1985
              • 935
              #36
              How do you clean a rusty cap, can you soak it in something?
              • Ara G.
                • January 31, 2008
                • 1108
                #37
                Ralph
                I have had great success with OOOO steel wool. Can get it at Home Depot. They vary in grades, O, OO, OOO, OOOO. I actually use it on my restored radiator caps after they acquire some white oxidation. It does not harm the finish on the cap and cleans it extremely well....Good luck...Regards. ARA
                • Glen C.
                  • November 1, 1985
                  • 193
                  #38
                  I have a 15# RC-26 cap that looks exactly like the one Don Lowe has posted, except mine has two thin closely spaced lines around the left side AC logo. There is also a very slight double stamp at the bottom of the C & the 2 in the RC-26. What may be of more interest is the back side of the cap. On top of (with cap upside down) the aluminum disc that goes under the spring is a 3/8" wide circular floating seal or gasket. The seal is black rubber or some composite material that has small white/grey flecks in the material. I have probably a hundred or so old radiator shop discarded caps, but have never seen a cap with this gasket. It does not appear to be something homemade or added after production. Maybe I missed the thread where this was discussed. If not, was this part of a production RC-26 cap? Has anyone else seen these gaskets on their RC-26 caps?
                  Your Message
                  • Peter L.
                    • May 31, 1983
                    • 1930
                    #39
                    Glen - The AC RC-26 radiator pressure caps came with a composite material gasket as you describe. In fact from what I have seen all of the AC radiator pressure caps like the 307 and RC-26 caps that were used on Corvettes with the aluminum overflow tanks had that gasket. Pete
                    • Glen C.
                      • November 1, 1985
                      • 193
                      #40
                      Peter, I probably should have known that, but did not. Thanks.
                      • Floyd B.
                        • November 1, 2002
                        • 1050
                        #41
                        I hate to dredge this back up again but I'm trying to figure out which cap I should be looking for. I have an early production (#3407) '69 L-36 4spd w/o A/C. My guess is that I need one of the caps posted by Alan or Don - the only difference being the orientation of the "15 #, RC-26" Script. Though the rivet on Don's appears to have a larger/flatter rim encircling the outside of the rivet.
                        For what it's worth, I have posted a picture of the typical repop being sold for $30 by the usual suspects. Notice the placement, size and spacing of the "15 #, RC-26" and open arrow heads. I also see several other subtle differences but I won't belabor the point.
                        "Drive it like you stole it"
                          Floyd -
                          Which cooling system (radiator and expansion tank) do you have?
                          • Floyd B.
                            • November 1, 2002
                            • 1050
                            #43
                            Aluminum expansion tank.
                            • Mark D.
                              1984-96 Team Leader
                              • June 30, 1988
                              • 2157
                              #44
                              RC26 but, any repop cap is one that Ray Charles could easily detect.
                              Kramden
                              • Paul O.
                                • August 31, 1990
                                • 1716
                                #45
                                Floyd
                                The normally expected radiator cap for a 1969 L-36 non A/C with aluminum expansion tank is a RC-26. Here is a photo of said cap this one has been restored. Also the rivet is not flat across it has a raised rounded ring above the surface of the cap body and in the center it has a valley maybe about an 1/8" to about 1/4" in depth. Also no auction on this item sorry
