C1 - Constructed my spare tire cover board - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2594
    No big deal you say, well I also constructed the plywood. From the research I've done while working on my 1960 restoration, the reproduction boards are not the correct wood, fir plywood or something similar rather that souther yellow pine. And the color is often more black overall than the originals. I did research on this forum as well as broadly on the internet and was not able to find any 3/8" 5-ply plywood as the originals were constructed.
    I happen to have a decent home woodworking shop. So I started with rough sawn 4 quarter souther yellow pine boards, planed them smooth and cut to 6" wide boards. This allow me to resaw them edge wise on the band saw. To make up the 3/8" plywood I needed thin strips that were 1/16" (0.0625") thick and 3/32" (0.09375) thick, so I resawed the board a little overside so that I could do the finish size with the thickness planer.
    If this doesn't judge better than a reproduction board, I will be very disappointed . The only negative is that I was unable to come up with an easy way to add any of the football shaped patches, but I have seen a number of pictures of what were identifed as original boards that did not have the patches. I also made my own posi CAUTION decal. Per the 1958-60 Corvette Restoration Handbook, the fonts are all wrong on the reproduction decals and from pictures of originals, I believe the repros are also more red that the original, so I also adjusted the color a little.
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Dan D.
    • November 5, 2008
    • 1323
    Re: C1 - Constructed my spare tire cover board
    Very nice. you could probably sell these boards. What stain did you use - if you don't mind me asking? -Dan-
    • Kenneth B.
      • August 31, 1984
      • 2091
      As a retired wood patternmaker you did a hell of a job. How long did it take to make it? That is a lot of work. I don't think you need any knothole plugs.
      KEN
      • Donald H.
        • November 2, 2009
        • 2594
        I used the Cabot Ebony stain. I used the Cabot conditioner also to prevent the sap wood from absorbing to much of the stain.
        I didn't keep track of my time, but it was a number of hours. It took many hours to plane the thin boards. Had to make many passes of extremely shallow cuts to keep from shattering the thin strips passing thought the thickness plane.
        Don Harris
        • Al E.
          • September 5, 2011
          • 313
          Don,
          Please publish your album, your photos are awesome. This trunk area looks like a masterpiece . The best I have ever seen.
