C2 vent glass code - NCRS Discussion Boards
C2 vent glass code
  • Doug L.
    • March 14, 2010
    • 442
    C2 vent glass code
    My '64 convertible has a replacement ("Safety Float") vent window on the driver's side. I want to replace it with a Safety Plate vent glass having the correct date code. I'm stuck on whether the vent glass is tinted or clear. The original invoice says "Tinted Windshield" but does not show the option code A02 (or any option codes). The passenger vent glass, that I believe is original, has "AS2" and the date code "CA" (correct for my car) etched in the glass.
    Does the "AS2" indicate anything about the tint? Is there any way to tell if vent glass is tinted aside from trying to see the tint?
    Thanks-Doug
  • Bob R.
    • June 30, 2002
    • 1596
    Re: C2 vent glass code
    AS2 has to do with the clairity of the glass and nothing to do with the date or color. All side wiondows are stamped AS2.
    • Scott S.
      • September 11, 2009
      • 1961
      Thanks-Doug
      Doug,
      If the passenger vent glass that you believe is original was tinted, it will say "SOFT-RAY" above the "LOF" logo.
      Your tinted windshield should also have "SOFT-RAY" above the "LOF" logo, with "SHADED" above "SOFT-RAY".
        Thanks-Doug
        Doug -
        What's on your driver side window and the passenger side window and vent window? All four pieces of side glass match (tinted vs. clear), whether they're "Safety Plate" (clear) or "Soft-Ray (tinted)".
        • Doug L.
          • March 14, 2010
          • 442
          Hi Bob, Scott and John,
          The passenger door and vent are both AC (September '63) The driver door is YC (October '63) The car is December 13, '63 build-date.
          All of the side glass is "Safety Plate" except the "Safety Float" driver vent. The windshield is "Soft Ray", so all of this seems to agree with the "Tinted Windshield" (apparently the A02 option) notation on the original invoice. I found a left vent, Safety Plate, AS2 CC clear glass that I'm going to buy.
          Thanks for all your help.
          • David L.
            • July 31, 1980
            • 3310
            The "AS-2" is an American Standard glass classification.
            "AS-2" = Laminated or tempered glass, side/rear only
            "AS-1" = Laminated glass, windshield only
            Dave
