radiator tag placement - NCRS Discussion Boards
  • Stephen J.
    • November 1, 1982
    • 24
    Just purchased a new deWitts radiator for my 57. I also got a new ID tag. Where does the tag mount? Is it painted? What's the best way to mount it? Thanks.
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: radiator tag placement
    The tag mounts on the back surface of the top tank centered from left to right and top to bottom.
    I think I mounted it with JB Weld, and it's been on for a couple of thousand miles and is still tight.
    It is painted black the same as the radiator.
    • Mike M.
      • May 31, 1974
      • 8408
      original tags werre soldered to the tank in the position that bruce describes. i soldered the ID tag to my 55 upper tank and it was a no brainer. mike
      • Gary C.
        Administrator
        • October 1, 1982
        • 17940
        Stephen, make sure it's above the radiator shroud. Bottom of the tag is right above the edge of the shroud. Gary....
        NCRS Texas Chapter
        https://www.ncrstexas.org/
        • John N.
          • February 1, 1975
          • 451
          Is the DeWitt 56-57 radiator a correct replacement or a direct fit and how about their 58?
          • Stephen J.
            • November 1, 1982
            • 24
            John it is one of the direct fit models. Hope to get it in this weekend. So don't know about fit yet. Thanks for the reply.
            • John S.
              • July 29, 2009
              • 640
              all 55-60 direct fit radiators come with a 58-60 mounting strap. on a 58-60 corvette the radiator will bolt like the original. 55-57 corvettes had a mounting strap that was one inch higher and the direct fit radiator will not have the upper hole and tacked nut on the bracket.
