Oct '69 build/Heater vacuum control supply - NCRS Discussion Boards
  • G A.
    • February 18, 2010
    • 229
    This car has the double pie-pan wiper door can. The can has a one red and one green vacuum line. AIM says to connect the heater vacuum line to the "W/S wiper vac hose". Sine the red and green hoses are selected vacuum, this won't work. I believe based on the dates on this page, that this is for the cars with a vacuum control on the passenger side, which mine does not have.
    Can someone with a later production car instruct me as to where exactly, and which line I'm to cut to splice in the "T" that supplies vacuum the the heater controls please??
    Dan
  • Lawrence M.
    • February 1, 1995
    • 404
    Re: Oct '69 build/Heater vacuum control supply
    The Heater/Defroster vacuum line connects to the yellow vacuum line from the wiper door vacuum relay on the drivers side firewall on late production 69's. I hope the attached picture is clear enough for you to see how the T splits the yellow wiper door vacuum line to allow the Heater vacuum line to connect.
    Larry
    2002 Z51 Convertible
    1969 L46 Convertible
      • 15632
      I hope this shows the HVAC take off on my January 1970. Just to the right and below the vacuum relay. Now your challenge is to find the black plastic T and the little spring clamp. Lots of luck.
      • G A.
        • February 18, 2010
        • 229
        [ATTACH=CONFIG]3970[/ATTACH]
        You mean this little jewel? Got one a year ago!!
        Thank you Lawrence and Terry, your efforts are much appreciated!!
        FWIW, I would bet the clamps are the same as the clamps found on the WW washer tubes.
        Dan
          • 15632
          It is a good thing you have those pieces in hand. They are not easy to come by.
          I would rate it a good chance they are the same spring clamps as the washer hoses.
          • Lawrence M.
            • February 1, 1995
            • 404
            Dan,
            First pay no attention to the picture I attched. You want the configuration in Terry's picture. Sorry if I caused any confusion. Second the AIM does list the same number for the washer hose clamps and heater vacuum clamps.
            Larry
            • Floyd B.
              • November 1, 2002
              • 1051
              I'm dredging up this old thread because I need one of these 3/8"x1/8"x3/8" vacuum tees. Does anyone know where I can find one? My searches of the usual suspects and google haven't been successful yet. Thanx.
              "Drive it like you stole it"
