Brake Fluid removal - NCRS Discussion Boards
Brake Fluid removal
  • Gerald C.
    • June 30, 1987
    • 1314
    Brake Fluid removal
    Unfortunately, I spilled some brake fluid down my firewall and can't seem to get it completely clean. I've tried Gunk, Simple Green.... and when I think I've gotten everything and I repaint the firewall, the paint starts to peel again!
    The engine is out, so I've got pleanty of room to do a proper clean-up.
    Any helpful ideas? I've searched the archives and didn't find anything under brake fluid removal.
    Jerry
  • Larry M.
    • January 1, 1992
    • 2703
    Re: Brake Fluid removal
    Jerry
    Jerry:
    Is it DOT 3 (glycol based) or DOT 5 (silicone based) fluid ?? This will make a difference.
    Larry
    • Peter M.
      • April 8, 2007
      • 570
      Assuming its DOT 3, or DOT 4 (glycol based), use denatured alcohol to thoroughly remove the spilled brake fluid.
        • 15706
        DOT 3 or 4 is water soluble, so soap and water should remove it, but it can mar paint, so that might be the problem.
        I don't know what will dissolve DOT 5.
        • Gerald C.
          • June 30, 1987
          • 1314
          It's DOT 3, glycol based, so I'll try the denatured alcohol or the soap and water.
            • 6960
            Jerry, I don't know if your having a reaction from two different types of paint, sometimes lacquer over enamel will cause the paint to lift. I have had this happen to me. Dot 3 brake fluid breaks down with soap and water generally.
            Hows the 67 doing? Is the engine back in?
            • Gerald C.
              • June 30, 1987
              • 1314
              Ed,
              Two things:
              1. I'm using the John Deere paint for my firewall. It's held up in the rest of the engine compartment, so I thinks it is the brake fluid.
              2. The M/C is leaking from behind and I'm afraid I need to take it out and have it rebuilt. I don't know what haapened because I didn't disturb it in the first place. May be bad timing for the seals to go!
              Jerry
                • 6960
                Jerry, sometimes cured paint and the re-apply of the same paint will cause a problem you'll have to read the can directions. maybe a note on it somewhere.
                • Tom N.
                  • May 6, 2012
                  • 42
                  One of the BEST primer from a can is Krylon Ruddy Brown primer, try first applying
                  a light to medium coat first, if it lifts the paint. Stop and I would clean it with a acetone
                  or lacquer thinner. Start from square one, no easy way when comes to painting.
                  • Gary S.
                    Super Moderator
                    • February 1, 1984
                    • 460
                    Might want to also try a self-etching primer after your efforts to clean up the firewall. Sems, Rustoleum to name a few I have used.
                    Avatar--My first ever vette, owned 3X since 1977, restored 1993-2024. Top Flight Award 9/14/24
