C-1 Rebound Strap Installation - NCRS Discussion Boards
  • John L.
    • February 1, 2005
    • 207
    This question is not as much about how to install the rebound straps on the rear of the C-1's .
    I have not installed the rebound straps on my completed 1954 frame - and it will be some time before I mount the body giving the extra weight to compress the springs. It seems to me that having to compress the rear springs and then riviting up the straps that when all is said and done the rear axle will be keeping the straps in quite a bit of tension until weight is added thus releaving the tension.
    My question is - are there any drawbacks to having the belts in tension for an extended peroid of time or should I wait until closer to the time I set the body down to rivit the straps. Also wondering about the springs themselves.
    orrrrr am I concerned about nothing here??
    appreciate what others have done.
    John Lanning
  • Kenneth B.
    • August 31, 1984
    • 2087
    Re: C-1 Rebound Strap Installation
    Why not wait to you are ready to hang the body. I would not want the tension on the straps for a long time.
    • Jerry G.
      • April 1, 1985
      • 1022
      When I compressed the spring and installed my original straps, they tore and broke. Might have been because original but there is a LOT of tension there . i'd wait
      • Dan B.
        • July 13, 2011
        • 545
        I would also wait as suggested, but think about it this way, when the car is off the ground as on a lift, the full weight of the rear axle is present on the straps. Straps in good condition should not break under this load. My .02 cents. Dan
        • Chris S.
          • January 1, 2000
          • 1067
          I installed my straps with the body off
          the chassis sat for over a year and there was no issue with the straps
          plus with the body off - there is alot more room
          1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
          Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
          1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
          1957 Corvette - FI 3 sp - Black and Silver
