I discovered after removing half the ignition shielding and everything holding the tube in place that it was impossible to remove it; either from the top or the bottom. Powerglide dipstick tube prevented it from rotating enough to clear the frame. It looks like I would need to remove the starter/solenoid and the PG dipstick tube to pull it out from the bottom.
Any suggestions?
Any suggestions?
