Can't get the plug off the side of the 4 speed transmission to check the fluid level. It has apparently been stuck for a long time since most of it was rounded off before I started on it. I tried vice grips, plumbers monkey wrench, everything in my tool box. There is very little left of the plug to get a grip on. Is there any other way to check te fluid level? There is also no drain plug on this trans. I am assuming this has been like this a long time therefore I need to find a way to check the gear oil level.
Ted
Ted
