63 Spare Tire Tub - NCRS Discussion Boards
63 Spare Tire Tub
  • Tim S.
    • May 31, 1990
    • 704
    63 Spare Tire Tub
    Can someone post some pics of the difference in the 63 tire tubs (or give a great explanation) versus the later units? In advance, thanks for your consideration.
    Tim
  • James S.
    • July 31, 1990
    • 126
    Re: 63 Spare Tire Tub
    Thread: 63 versus 64-67 Spare tire carriers.
      • 6942
      Tim
      Tim, The difference is the earlier cars before March sometime the lower lip of the tub is about is about 3/8 inch, And later cars (late 63 and 64 up) it was about 1 inch.
      • Harry S.
        • July 31, 2002
        • 5297
        I've seen late April cars with the early style tub. I'm not sure when the switch to the new style was.
        • Doug F.
          • November 1, 1983
          • 322
          you can make an early one out of a late one real easy, the other way around is much harder
          • James S.
            • July 31, 1990
            • 126
            Doug, you are correct on the tub; however the lid "V" bar is unique to a '63.
            • Joe R.
              • July 31, 1976
              • 4550
              Gentlemen,
              Not only physical differences with the lip and cover but the composition of the 63 was quite different from the later spare tire tubs. The 63 had a definite black apperance with distinct white fiberglass strands closer to the surface. Very similar to the outer heater box cover. Don't know how long or if there was a change in composition later in the year but all original 63's I have ever seen had the darker fiberglass material.
              JR
