Ignition Shield Help - NCRS Discussion Boards
  • Mike M.
    • July 24, 2011
    • 297
    There is a small 'ground' on the front of the main ignition/ distributor shield on my '65 (and many others). This little metal ground is gone on mine. Is there a way this can be fixed? Is there someone who specializes in such?
    Mike
  • Alan D.
    • January 1, 2005
    • 2046
    Re: Ignition Shield Help
    Long Island has them, 30-30A,B,C,orD Now I've heard something about the rivets not being (or insallation of) correct? check!
    • Rob M.
      • April 30, 2003
      • 657
      Mike,
      The clip is available from LIC as stated. The trick is being able to rivet the new one on the shield again. When I did this project, I had help from Dan Holstein who had done his before me. There is good information on this subject in the archives by Jerry Fuccillo.
      Good luck
      Rob
      '66 327/300 Regional Top Flt
      '08 6 speed coupe
      • Don H.
        Moderator
        • June 16, 2009
        • 2269
        Here is the ground clip on an unrestored April 65 build L79.
        I have replaced the clip on my distributor RF shield twice, and it is tricky little task. I have a special little punch that precisely fits the open end of the aluminum rivet, and need a friend to hold a backer against the head of the rivet and also spead the shield open a little to make room to swing hammer on the punch.
