I read with much interest the recent post on Wonderbar radio reception problems. I have much the same issue on my 74' with a checked/ repaired OEM radio with new speakers and new antenna lead. FM reception is fine but AM reception is very, very poor and improves if I touch the antenna mast. T******* the radio provided no help. I removed the ground plane, un-rivited it and cleaned up the aluminum corrosion and oxidation on the steel center plate and reassembled making sure the ground contact with the frame was good and this provided no help. I changed the antenna mast out with an OEM mast (mine is a reproduction mast) from a 75'-again no help. At this point I am assuming it must be an issue with the new antenna lead which was purchased from Paragon about 2 years ago.
Questions:
1.) anyone else have this problem on a C3 and how was it solved?
2.) What vendor should I use to purchase another antenna lead that has a good chance of working?
Questions:
