Mystery Engine - NCRS Discussion Boards
Mystery Engine
  • Peter G.
    • September 30, 1992
    • 135
    Mystery Engine
    Can anyone provide some input or suggestions about this engine?
    OK to PM me.
    Thanks!
    Dr. Pete
    www.CorvetteLegends.com
  • Jim L.
    • September 30, 1979
    • 1816
    Re: Mystery Engine
    That's an all aluminum 283 with prototype block and quasi-production aluminum heads.
    What do you know of its history?
    Jim
    • Peter G.
      • 135
      Re: Mystery Engine
      I really don't know much about it's history.
      The most recent owner of this engine unfortunately passed away.
      Dr. Pete
      • Rick G.
        • March 1, 1983
        • 274
        Re: Mystery Engine
        I agree with Jim. I saw a all aluminum block with an identical date at the Hot August Nights Swap Meet during the late 1980's. I can't remember the vendor but would not be surprised had it been Jack Podell. First and only one I have ever seen. If memory serves me correctly, the price was around $3k for the bare block, no heads were available.
        • Bruce T.
          • February 1, 1978
          • 60
          Re: Mystery Engine
          [ATTACH=CONFIG]39544[/ATTACH][ATTACH=CONFIG]39545[/ATTACH][ATTACH=CONFIG]39546[/ATTACH][ATTACH=CONFIG]39547[/ATTACH]
          OK to PM me.
          Thanks!
          Paul Siano has one of those aluminum 283 blocks in his V8 Corvair.
            • 15621
            Re: Mystery Engine
            More 0- casting numbers from the old days -- and twin turbos to boot.
            • Dick W.
              • 10483
              Re: Mystery Engine
              I am wondering, with the turbo set up, if this is not an aborted Indy stock block engine. I know that there were several attempts to build stock blocks for Indy. I remember seeing the Pontiac engine at Ray Nichels shop 40 years ago.
              Dick Whittington
              • Chuck G.
                • May 31, 1982
                • 2038
                Re: Mystery Engine
                http://www.automobilemag.com/reviews...corvair_corsa/
                I live near Crystal River, Florida now. There is a guy, maybe the same fellow, who has a Crown converted Corvair with a 59 all aluminum 283 in it around here. I've seen the car at several shows at at several "cruise in" events.
                MUST be the same car.
                Chuck
                  Re: Mystery Engine
                  The cold intake side of both turbos have what appear to be professionally-made adapters for Weber side-draft carburetors (probably 58mm DCOE's).
                    • 15706
                    Re: Mystery Engine
                    It appears to have "integral" valve guides, just like cast iron heads. I think that was the downfall of these early aluminum heads. GM didn't want to spend the money in production to install guide inserts as was/is typical for aluminum heads, then and today, but it didn't work.
                    • Peter G.
                      • 135
                      Re: Mystery Engine
                      Thanks for all the comments. Here is a photo of the engine stamp pad.
                      I would like to figure out where this engine came from and what it was used in.
                      Its difficult when the people you need to talk to aren't around anymore!
                      I have an idea, but its only speculative.
                      If anyone else has some suggestions, I would greatly appreciate it.
                      Dr. Pete
                      • Clem Z.
                        • January 1, 2006
                        • 9427
                        Re: Mystery Engine
                        bill howell at GM was around in this time frame working on projects like this.
                        • Loren L.
                          • April 30, 1976
                          • 4104
                          Re: Mystery Engine
                          Dr. Pete:
                          What you have is a very common reference in Chev. Engineering (other than writing "Record Engine" in crayon, for
                          example) - it is undoubtedly the Work Order # that built this motor - 17495-12A. The 12A would probably reflect the
                          12th ( or 13th) variation off of the original 17495 WO.
                          [ATTACH=CONFIG]39582[/ATTACH]
                          • John N.
                            • February 1, 1975
                            • 451
                            Re: Mystery Engine
                            After contacting Howell, I would consider Gale Banks. Banks is in recent history a leader in turbocharging and has run GMC project trucks at Bonneville. Gale might know the history.
                            Have a great weekend.
