C2 Trailing Arms - NCRS Discussion Boards
C2 Trailing Arms
  • Al R.
    • June 30, 1988
    • 688
    C2 Trailing Arms
    Approx. when did all C2 trailing arms begin receiving the 2 holes for mounting the rear stabilizer bar? I know big blocks got them, but I'm mainly questioning the small block starting date. TIA
  • Gerard F.
    • June 30, 2004
    • 3806
    Re: C2 Trailing Arms
    Al,
    I don't think the C2 small blocks ever had trailing arms with the 2 holes for mounting the rear stabilizer bar from the factory. At least my late 67 S/B trailing arms didn't have them.
    I think the rear stabilizer was only used on the big block cars. Maybe the service trailing arms had the holes.
    When I replaced my trailing arms, I was given the choice of big block or small block trailing arms, with the only difference being the holes for the rear stabilizer.
    Jerry Fuccillo
    • Wayne M.
      • March 1, 1980
      • 6414
      Originally posted by Gerard Fuccillo (42179)
      ..... Maybe the service trailing arms had the holes...
      For service here's the parts history.
      The 1st July '65 revision of the P&A30 shows both '65 trailing arms for 327 engines; Gr 5.382 # 3864035 and 036, respectively for left and right. It also shows (only) the right torque control arm for 396 engines, #3874770, so I'm guessing the holes made the difference.
      The history lists show the numbers 3864035 replaced by 38747769 on 10-65, and the 036 with 770 on 11-65, both supposedly for big and small blocks, as the displacement was no longer quoted.
      Of course, '63 and '64, and '65 with disc brake delete still used another set of trailing arm #s.
      • Gene M.
        • April 1, 1985
        • 4232
        I think you will find that the trail arm holes for the sway bar were done off line as needed. I guess it is possible that a small block got the holes out of operator error thinking a bb was in que for build.
        • Al R.
          • June 30, 1988
          • 688
          I was just wondering as my original TA had the holes. Gene, you might have a point, because my car had the tank sticker for a 427 engine installed on it, even though it was a small block car. Feb 67 car. I now have TA w/o the holes in them
          • Tom D.
            • September 30, 1981
            • 2139
            And never had a 427 engine?
            https://MichiganNCRS.org
            Michigan Chapter
            Tom Dingman
              That's correct - there was no such thing in the plant as a SB or BB trailing arm; they arrived from Chevrolet-Warren with no holes, and if they were to be installed on a BB car, the two holes for the rear bar bracket were drilled in an off-line bench drill fixture. That's why the hole dimensions are shown in the A.I.M.
              • Al R.
                • June 30, 1988
                • 688
                Thanks John, I knew you would know for sure. Tom, no, it never had the big block stuff. The 427 tank sticker had the same exterior color listed as mine, but where mine is 450 interior, this 1 was B blue. I'm 2nd owner, so I know for sure it was a sticker mix-up. I've posted before hoping someone had my original sticker. I was also hoping that by chance that they had mine and i had their's, so we could swap-out. I'm sure they could use paperwork for a 427-435 for documentation more than I need it, since I have other doc's for this car. Anyway, I may repost it at a later date and see what happens.
                • Ralph S.
                  • February 1, 1985
                  • 935
                  What zone and dealer number is on the build sheet
                  • Patrick B.
                    • August 31, 1985
                    • 2009
                    I know its not a C2, but 70 (and I presume 71 &72 also) LT-1s came with trailing arms drilled for rear sway bar hardware. I have always believed that this was because they shared the heavy duty rear stub axles as well as rear end yokes with big blocks. Until the service replacement trailing arms became so common, it was easy to tell a real LT-1 by the holes in the trailing arm.
                    • Al R.
                      • June 30, 1988
                      • 688
                      Ralph, I'm in TN for a few days. When I get back Thurs. night, I'll try to remember to post everything on the tank sticker.
                      • Al R.
                        • June 30, 1988
                        • 688
                        Ralph, I tried to send reply Thurs. But A Virus wiped out my computer. Here's what the sticker says off my tank ID #812671 Rec'd 1/12/67 Ex DOP 2/24/67 Order # 00278 Zone 11 Dealer 201 Conv Ermine White Bright blue vinyl int 425Hp Trans Ign 370 Posi 4spd close ratio M21 775 WSW blue conv top AM/FM tinted glass F41 susp dual side exhAUST My car 327-300 PS PW PB Auto A/C 2tops (blue soft top) all tinted glass AM/Fm Ermine white non posi traction forgot ratio (308 or 323?) Blue/white interior Ser 3 115.. Anybody with serial # close to this that can check their tank sticker for mine-- maybe we can change out
