Testing coil spring rate - NCRS Discussion Boards
  • Tom L.
    • October 17, 2006
    • 1439
    I've got the front of my car apart and want to test the rates of my springs to make sure they are winthin spec. The reason is the car didn't sit even from left to right, was too low and had 1/2" shims under each of them. I have access to a spring tester but I'm not sure what numbers I should be getting.
    I've attached a chart (Below) taken from a document availible at the GM Heritige center. It provides the specs for the springs. The tags on my springs are marked "HV", correct for my application, and they stand about 15" tall out of the car. Before I go to the tester I've got a couole of questions.
    Spring chart.doc
    What is meant by "Free Height".
    Also, does "Working height" mean the height of the spring installed with the car on the ground and loaded? I'm assuming that it should take, in the case of my springs, 1620 lbs. to compress the spring to 9.99"
    As always, thanks for the help!!!!
  • Bill M.
    • April 1, 1977
    • 1386
    Re: Testing coil spring rate
    [ATTACH]39495[/ATTACH]
    The chart's free height is wrong for your spring. I get (1620 / 325) + 9.99 = 14.97. That is the height of the spring out of the car.
    Working height is in the car with 2 passengers and luggage (design load). edit: Yes, your spring should be 9.99 at 1620
    • Tom L.
      • October 17, 2006
      • 1439
      Thanks, that makes sense. I figured something was up. I'll be checking the rates this week, I'll post the results.
