Looking for Advice with a Judging Issue - NCRS Discussion Boards
  • Michael M.
    • June 5, 2011
    • 30
    I just purchased four new radials for my 65 convert. that will be judged this June. I understand I will loose points with the radials even though they were mounted on the original rims. My spare is an original Firestone bias ply mounted on an original rim. My question is, should I also replace the spare with a radial so all are the same, or keep the original bias ply? I understand it should go back to as original as possible however I still want to drive the car to Bloomington and don't need old bias ply tires coming apart damaging the fenders as this is not a trailer queen.
    Thank you for your time in reading this and if you choose to reply.
  • Dennis C.
    • June 30, 2002
    • 888
    Re: Looking for Advice with a Judging Issue
    Mike,
    The spare tire is judged separately and doesn't have to match the tires on the car. You will receive more originality points with an original tire as long as it matches what could have been on the car from the factory.
    Give some thought to what you will do if you get a flat while on the road. It might not be wise to drive on an original tire.
    Dennis
    • Paul D.
      • September 30, 1996
      • 491
      Keep the original spare if it is indeed "the original" or at least a correct replacement. It is my understanding that the spare wheel/tire is judged completely seperate from the 4 road wheels/tires. Good luck! Chip.
      • Michael W.
        • April 1, 1997
        • 4290
        Is this an NCRS event or Bloomington Gold?
        • Michael M.
          • June 5, 2011
          • 30
          Bloomington
            • 15631
            Bloomington
            Then you will be best served by addressing your question to those folks at www.bloomingtongold.com. The answers you have received are correct for NCRS, but may or may not apply at Bloomington Gold.
