I've been rebuilding/restoring my front suspension and steering on my 66 BB. The front springs were installed upside down and had cushions at both end seats. Springs must have been removed to install the cushions; also, lower ball joint was bolted not riveted. I re-installed the springs with the closer spaced coils toward the top and decided to re-install the cushions as the car was at a correct ride height by measurement and appearance. I installed the springs on the same side they came from. The result is no good...car sits much too high; camber unbelievably out of wack. I guess I'm going to have to do it over again...not something I'm looking foward to as installing the springs with the car on stands is a b.....h. To remove I used one set of jaws of a internal spring compresser bolted thru the upper shock mount hole....worked OK. To install I used a thread rod from the upper shock mount hole thru the lower control arm .Along with this I used a floor jack to lift the lower control arm by the shaft bolt. Was a very difficult as the spring was hard to get in place; kept wanting to move outward towards the tire. Question is should I buy new springs (if I do I'll use Eaton) or do I remove the cushions and hope for the best.
Vin
Vin
