Crack repair - suitable adhesive? - NCRS Discussion Boards
  • Oliver S.
    • December 1, 1999
    • 343
    Hello,
    which product would you use to repair this crack above the right door hinge? Normal epoxy resine together with hardener and Microfibres as filler or - as I've read here - fusor 100ez? Most other brands mentioned here aren't available in Germany. Thus the restriction.
    Oliver
  • Russ S.
    • April 30, 1982
    • 2162
    Re: Crack repair - suitable adhesive?
    I would grind it out concave and use polyester resin and fiberglass mat.
