68 wiper door canister/actuator - NCRS Discussion Boards
  • Rich G.
    • August 31, 2002
    • 1406
    Turned the wipers on today and the actuator rod broke at the threaded portion on the rod that comes out of the canister. It broke almost where the threaded portion starts, leaving one or two groves.
    This is the correct canister for this car (July 68 build) and I would like to avoid a service replacement. Anybody fix these or is it impossible?
    Btw, the door is freed up now, I had not turned the wipers on for a long time and should have checked before I did, but that's all water under the bridge now. It's also likely that the canister was not aligned with the rod, which is probably why it broke. The canister was tilted down in front, so it tried to bend the rod when pushing. I noticed that too, but never thought enough about how it works to realize that would be a problem.
    Anyway, it needs to be fixed now.
    Rich
  • Lawrence M.
    • February 1, 1995
    • 404
    Re: 68 wiper door canister/actuator
    You could try Bob Demmel who frequents the Tech Board and advertises in the Driveline. He repired/restored my pie pan style and I was very pleased with his work.
    Larry
    2002 Z51 Convertible
    1969 L46 Convertible
    • Rich G.
      • August 31, 2002
      • 1406
      Thanks Lawrence
      I just spoke to Bob. The good news is he can fix it. The slightly worse news is he is backlogged until July, which I guess is good news for him.
      Thanks for the tip
      Rich G
