Correct Fast Idle Speed at Ops Check - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2673
    What is the ball park range for the fast idle speed during the flight judging Ops check... 1,500???
    Also how do you adjust the fast idle setting on a Carter AFB?
    James West
  • Michael G.
    • January 1, 1997
    • 1251
    Re: Correct Fast Idle Speed at Ops Check
    James West
    1500 rpm will have you in the ball park. Your service manual will cover fast idle setting on your Carter.
    • Stuart F.
      • August 31, 1996
      • 4676
      Driver's side of carb; look for fast idle cam linkage (link arm from choke shaft end) and screw that contacts idle cam. Check speed (RPM) when screw is on highest notch on cam. If close, and you want to tweek it up or down, it is best to shut engine down as it is difficult to get tool on screw with engine running on high notch. Make adjustment, then restart engine making certain screw is back on high notch. It is not necessary for choke baffle plate to be completely closed, in fact it won't run too long that way. Let it relax to the unloaded position, assuming that it is properly adjusted as well. It is best to consult an instruction sheet or manual to do a complete linkage adjustment check if in doubt. These linkages don't easily get out of adjustment unless some commando has messed with it.
      Stu Fox
      • Clem Z.
        • January 1, 2006
        • 9427
        some of the fast idle specs in the GM shop manuals are for a warmed up engine so make sure you read the fine print when you set your fast idle cam.
          • 15706
          Most AFB equipped OE engines have a fast idle spec of 1750, hot. In other words you set the fast idle with the engine fully warmed up, and 1750 hot will result in about 1500 cold.
          Whenever asking a technical question about an engine one should list the model year and engine option, and the appropriate service manuals will have all the carburetor adjustment specs and a detailed description of how to check and adjust everything.
          • Clem Z.
            • January 1, 2006
            • 9427
            i would think the viscosity of the engine oil and the ambient temp would effect the cold idle speed do do your homework before the PV test
              The fast idle specs in the GM Shop/Service manuals are a calibration number, based on having a fully warmed-up/normalized engine and setting the throttle tang on the highest step of the fast idle cam; neither of those conditions will ever occur during Operations judging or a P.V.
              • Michael H.
                • January 29, 2008
                • 7477
                Here's the original discussion on the "fast idle speed" discussion. I think it was decided by most judges after that time that there was no such thing as a spec on cold engine fast idle speed.
                https://www.forums.ncrs.org/showthre...speed&uid=3162
