I am preparing my rare (Red/red L76 A/C) 1965 Coupe for the National NCRS Convention. My hope is for a National Top Flight Award for this car.
I just sat down and wrote down all the things I had to correct after judging teams deducted points from my car's score when it was last flight-judged. For those of you who also may be contemplating such a goal, just for informational purposes, here is my list of things completed since the first of the year (4 months):
- Replace scratched hood release handle with correct unit and attach without existing clip (NCRS Interior Sec. #8);
- Adjust doors at top to eliminate cause of water leaks (wetting foot-well carpet and inside door panels on both sides);
- Strip & refinish fan to restore appearance;
- Replace the incorrect (finish) screws at bottom of headlight buckets with black phosphate screws (NCRS Ext. Sec. #12);
- Remove black inkjet markings on fan clutch or install a rebuilt original fan clutch (NCRS Chassis Sec. #5);
- Refinish frame in front of steering box area;
- Replace lower radiator hose with correct unit with part number visible; Install correct date-coded clamps; (NCRS Mech. Sec. #13); (parts: $39)
- Pressure line assembly to oil pressure gauge: Remove incorrect copper tubing and install copper-clad steel tubing connecting to a brass bushing at the rear of the block behind the intake with a brass ferrule fitting; (NCRS Mech. Sec. #12); (parts: $19)
- Refinish the red painted area of console around shifter;
- Replace bell housing inspection cover bolts with correct slotted bolts (NCRS Chassis Sec. #10);
- Install missing spark plug shield & wing bolts on front right side of engine (under A/C compressor);
- Replace all five Western repro KO wheels with correct steel wheels and 4 wheel covers (NCRS Exterior Sec. #21);
- Replace the rusty, incorrect screw on glove box door latch (NCRS Interior Sec. #7);
- Trim the top attachment of inside door pulls to eliminate excess (NCRS Interior Sec. #1);
- Adjust passenger door to correct sagging;
- Replace incorrect (both) and inoperative (left) courtesy light switches in door jambs (NCRS Interior Sec. #2);
- Replace rag joint with correct parts; (NCRS Chassis Sec. #2);
- Replace red painted rivets in the side dash attachment (inside door opening) with correct black-color rivets (NCRS Interior Sec. #5);
- Replace incorrect A/C hoses with correctly marked hoses; (NCRS Mech. Sec. #17);
- Replace incorrect dehydrator with correct unit; (NCRS Mech. Sec. #17);
- Replace incorrect condenser with correct unit; (NCRS Mech. Sec. #17);
- Correct originality issues (wrong gasket and no paint) with thermostat housing; Paint housing silver to match intake manifold (NCRS Mech. Sec. #6);
- Install (missing) black plastic seal inside door release knob (NCRS Interior Sec. #1);
- Correct the routing of power window wiring (visible in passenger door jamb) (NCRS Interior Sec. #2);
- Replace incorrect heater hoses with correct ribbed hoses (NCRS Mech. Sec. #13); (parts: $69)
- Remove gaskets from exhaust manifolds; Install correct French locks and bend tabs over, replicating correct factory installation (NCRS Mech. Sec. #11);
- Remove Pertronix electronic ignition and install an original coil & capacitor (NCRS Mech. Sec. #10);
- Replace incorrect intake manifold gaskets with correct gaskets (NCRS Mech. Sec. #6); (parts: $44)
- Replace worn air cleaner lid with correct unit; Replace incorrect wing nut (too thick) with correct unit (NCRS Mech. Sec. #5); Parts: $99
- Replace incorrect power antenna with a correct reproduction with a concentric groove on each section of mast; (NCRS Exterior Sec. #10); Parts: $615
- Repair both malfunctioning door vent window regulators; (NCRS Operations Sec. #29);
- Paint underside of hood on outside edge to follow straight line from brace (NCRS Chassis Sec. #4);
- Repair cause of loose rear attachment point of passenger-side chrome trim above side exhaust;
- Service dash clock to improve function (do NOT convert to quartz movement); Rebuild: $192.34
- Paint steering gearbox using semi-gloss black paint; (NCRS Chassis Section, #2);
- Replace incorrect heater fan motor with correct unit with vent (NCRS Mech. Sec. #17); Note: the existing fan motor discovered to be correct original with the cooling hose missing and the hole taped over;
- Correct door locks being on wrong side of car (Right: should be counter-clockwise to unlock, clockwise to lock Left: should be clockwise to unlock, counter-clockwise to lock) (NCRS Operations Sec. #30);
- Replace pitted and dull front grill with correct new unit; Insure that all screws are black on reinstallation (NCRS Exterior Sec. #14) new grill: $500
- Replace non-dated windshield with correct date-coded unit; Replace the incorrect windshield gasket with correct unit to eliminate poor fit of outside trim (NCRS Exterior Sec. #5); part-$375
- Replace incorrect flasher with a correct unit and install (missing) capacitor (NCRS Interior Sec. #14);
