Horns for 1957 - NCRS Discussion Boards
Horns for 1957
  • Theodore K.
    • December 1, 1985
    • 214
    Horns for 1957
    While workinig at rewiring my 57 Corvette, I discovered that one of the horns is missing. Does anyone have the correct PN for the 2 horns (A note & F note)? Does anyone know if the horns from other Chevy's of those years are the same. I suspect that they were interchangeable but don't know for sure.
    Ted von Kampen
  • Gary C.
    Administrator
    • October 1, 1982
    • 17657
    Re: Horns for 1957
    Ted,
    Corvette horns are unique to Corvette only. Following information from the 5th Edition 56-7 JM: 1957 horns after approximately VIN # 1500are 339 low note & 340 high note. 1956 thru early 57 are 759 & 760.
    Contact Joe Perri 312-307-1977 - Joe usually has several and does a great job rebuilding horns.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Theodore K.
      • December 1, 1985
      • 214
      Re: Horns for 1957
      Gary, thanks for the information. I will contact joe.
      Ted
      • John P.
        • January 1, 2006
        • 162
        Re: Horns for 1957
        Ted, Dave Evans currently has a pair listed on his web sight. Cant remember but think they are rebuilt. His web sight is Fueliedave.com John
        • Tom S.
          • August 31, 1994
          • 137
          Re: Horns for 1957
          Ted von Kampen
          Ted,
          How did you make out in your search for 1 horn. I need 1 also...pass side for mine with bracket. Any help welcomed.
          • David L.
            • July 31, 1980
            • 3310
            Re: Horns for 1957
            Isn't the only difference between the 57 Corvette horns and the 57 Chevrolet horns the bracket and it's location?
            Enclosed are 3 photos of a 57 Chevrolet "325" horn that I have in my collection. These old horns usually do not work and must be taken apart and rebuilt. Are reproduction brackets available?
            Dave
            • Theodore K.
              • December 1, 1985
              • 214
              Re: Horns for 1957
              Tom,
              I did learn somethings. If your car has a VIN before 1500, then you need the earlier set PN's 759/760 which were also used on basic chevy's. These have shown up on ebay and I recently unsusccefully bid on a pair eventhough my VIN is 1837. If your number is over 1500, then the 339/340. These are apparently very rare. Only used for 1/2 a model year, and only corvette. They are scarce and thus expensive. read all my thread and you will see a name to call and he does have some. He rebuilds them.The one I have is not correct and is the High note. This guy identified this as a service replacement by Chevy. HOpe this helps.
              Ted
              • Tom S.
                • August 31, 1994
                • 137
                Re: Horns for 1957
                Tom,
                Ted
                Ted, Called Joe Peri and got the right story and have 1 put aside. I watched the same pair sell on ebay for $77.xx or so but Joe said the main difference is the Corvette only brackets being shorter in length and having the mounting holes offset casing mounting issues. He has a few of the 759/760's but no 339/340's....hard to find and expensive just like th 63 horns. Thought I would share the info.
