Rear Axel Yoke threaded or not ? - NCRS Discussion Boards
  • Wayne P.
    • January 23, 2008
    • 444
    I took the half shafts off . They had retainer caps with bolts. Their are no threads in the rear axle yoke. My question is should I replace these caps with U Joint bolts ?.
    I am replacing one Axel yoke ( Threaded or not threaded that is the question )
  • John M.
    • January 1, 1998
    • 813
    Re: Rear Axel Yoke threaded or not ?
    Wayne, It should be a u bolt so it sounds like someone used what they could find, or it had an earlier life that involved more HP . The stock item is non-threaded with u-bolts.
    • Wayne P.
      • January 23, 2008
      • 444
      Great thanks for the answer. I believe at one point the car had a big block in it.
      I will order one from Wilcox
        Wayne -
        If the yoke had bolted caps retaining the U-joint (instead of U-bolts and nuts) but had no threads in the yoke for the bolts, what held the caps in place?
          • 43295
          Wayne -
          John------
          I'm wondering exactly the same thing!
          • Michael W.
            • April 1, 1997
            • 4290
            Longer bolts with nuts on the far side?
            • Gary R.
              • April 1, 1989
              • 1808
              Is this the axle you had .190" measured from the face to the snap ring? If so was it soft?
              Are you buying rebuilt Lone Star axles or new axles? The rebuilt axles have a hardened tip pressed in the end of the yoke. There is no center drill hole in them. The new ones have the center drilled hole and some I have found soft, others had the snap ring groove machined in the wrong place resulting in 040" + endplay.
              The std axles used had clear holes for u-bolts. The "HD" axles used caps and bolts although every diff I checked over the years that was broken by abuse was never a result of a failed U-bolt axle.
              • Wayne P.
                • January 23, 2008
                • 444
                Grade 8 bolts with lock washer and nuts. Regards
                  • 43295
                  Wayne------
                  This is a totally bogus set-up. Among other things, the u-bolt type axles are not designed or machined to accept caps. In fact, they are different forgings. You're lucky you didn't have some serious problems associated with this.
                  • Wayne P.
                    • January 23, 2008
                    • 444
                    That is what the car had. The caps fit fine. I am buying two new axles heavy duety drilled with caps. Thanks for all the info. I placed a repair sleeve over the companion flange . should help the oil leak. Thanks for the help
                    • Timothy B.
                      • April 30, 1983
                      • 5203
                      Wayne,
                      If by companion flange you mean pinion yoke, make sure you seal the splines in the yoke with some rtv or the leak path will be through the splines not the seal.
                      • Wayne P.
                        • January 23, 2008
                        • 444
                        Timothy thanks for the info.
                        Yes I got the info from this site on using the sealer on the pinion yoke. When I took it apart their was no sealant on the splines. I hope the axel yokes that I am buying are ok. Will check snap ring distance to determine if the same as originals. First time buying from Wilcox corvettes. Should rec in the next couple days. W
                        hile the rear end is out is their any advice on painting it colour ? thanks
                        • Timothy B.
                          • April 30, 1983
                          • 5203
                          Wayne,
                          If it were mine, probably a spritz of cast blast and that's it. Pay attention to the rear crossmember mounts (big rubber bushings), and make sure these are in good usable condition.
                          • Wayne P.
                            • January 23, 2008
                            • 444
                            I wanted to give a follow up. I placed a sleeve over the pinion yoke splines put the black rtv sealant over the splines enough to oozing out when the nut and washer were tightened down. I drove 5 or 6 times and it is leaking again. How did I notice this ? My wife asked me to clean her back windshield of her car > Yup grate to have a 4 poster. So I guess I have to start all over. Sweet while it lasted it gave me pleasure not to have a constant leak on the exhaust. Have a great day.
