Front Bearing Race Removal - NCRS Discussion Boards
  • George J.
    • March 1, 1999
    • 775
    I have met bubba and he is me. This weekend I was installing new wheel bearings on the front of my '65 and thought I had done enough research to perform the job correctly, but no. While removing the races, I used a punch to contact the small shelf of the race that is visible from the four notches in the hub from the back side. Well, the punch came in contact with the hub surface and nicked it in a few places.
    These kicks were very small and probably 0.1% of the surface area of the race seat, so after making sure there were no burrs I was able to install the new race with no trouble. I looked back at the old threads and noticed that someone had advised using a brass drift. That makes more sense, now, and I'll use that on the other side, which I haven't done, yet. I just wanted to make sure this was posted, so that others don't use punches, screw drivers, etc. for this. Of course, maybe everyone else already knew this, but in case there are others like me....
    I was able to purchase an installation tool, and would highly recommend that for installing. The races went in snugly and smoothly using it.
    George
  • Philip P.
    • February 28, 2011
    • 558
    Re: Front Bearing Race Removal
    Well it is good to know that "bubba" is alive and well, remember he kept these cars together before nothing but correct parts were an issue.
    Thanks for the information
    Phil
    • George J.
      • March 1, 1999
      • 775
      An update. It appears that it is not that easy to find brass drifts, or punhes without ordering them and spending some dollars. I had a hardware store cut some 3/16" stock to 8" lengths and used those. It worked perfectly and cost $6.
      The bearings that came out were Hyatt and the new ones put in were Timken, and Made in the USA.
      George
      • Ken A.
        • July 31, 1986
        • 929
        Flip over the old race & use to install new race.
          • 43247
          George
          George------
          I'm surprised that you could drive out a wheel bearing race with a 3/16" OD brass rod. That just does not seem stout enough to me.
          • George J.
            • March 1, 1999
            • 775
            Joe,
            It took patience, and working my way around, but it came out evenly. The new one went in snug, with a half dozen good hits of the bearing race driver. Everything felt like I would have expected it to. Most of the brass punches, or drifts I looked at ordering were not much bigger at the end than that.
            George
