54 Start Relay/N. Safety Switch - NCRS Discussion Boards
  • Brad H.
    • August 12, 2007
    • 724
    Car starts in 2nd, ok 1st and reverse, black wire from switch is closest to solonoid on relay and yellow is on other side at heater motor, are there adjustments or wiring problems? Thanks, Brad.
  • Willard M.
    • August 31, 1979
    • 422
    Re: 54 Start Relay/N. Safety Switch
    I have just spent some considerable time getting my NSS to operate correctly. Do you mean that car will not start in first or reverse, but will start in Drive? I think that the issue is your NSS and not the wires. I had my switch off and I checked continuity with the switch in various positions using the two wires, one of which goes up to your relay and the other to ground on the chassis. I think some adjustment is called for. Hope that helps. Bill
    • Brad H.
      • August 12, 2007
      • 724
      Willard, I read in another post on a 58 that the yellow wire went to the center screw and the purple to the left side facing the start relay, does wiring matter, how do you adjust the switch if it needs it, thanks, anyone else feel free to chime in on 54, Brad.
      • Willard M.
        • August 31, 1979
        • 422
        The relay, part number 1116886 has three poles. Looking from the front of the car the pole on the left (fender side) has the starter solenoid wire which should be yellow. The bottom pole has ignition wire which is purple, and the right side (engine side) pole has the black ground wire coming from the NSS. If it were me I would remove the switch and check that there is continuity when in neutral and park positions and no continuity when in the other positions. I suspect that the little 5 inch rod can be bent or straightened to give you what you need. As I'm sure you know, connecting the yellow and purple wires together will allow you to start in any gear in case your relay should go bad while out for a drive. Good luck. Bill
        • Brad H.
          • August 12, 2007
          • 724
          Hi Bill back again, I have no clue how this system works, wires vs levers, I dont see how a connection is made by shifting gears, or adjustment of that little rod, could you explain how it works and what the little rod does to benefit one? Thanks again, Brad.
          • Willard M.
            • August 31, 1979
            • 422
            Brad-Keep in mind that I'm a psychologist and not a mechanic. Basically the starting circuit is run through the relay which operates correctly when grounded (black wire). If you took the black wire and grounded it to the chassis the car would start in any gear. The same result occurs if you connect the yellow and purple wire together. Instead of the black wire being directly connected to the chassis it is routed through the neutral safety switch (NSS). this switch allows the ground to take place when the L shaped lever is in 2 positions(N and P). The rest of the locations of this lever results in an open (non-ground) circuit and hence no start. This L shaped lever has a hole in the end which receives one end of that small rod. The other end connects to the shifter mechanism. When the shifter is moved this bell crank system moves the NSS, hopefully putting the L lever where there is an open ground when you are in R,D, or Low. Hope that helps. Bill
            • Brad H.
              • August 12, 2007
              • 724
              Thank you Bill, That helps, what does bending the rod do to help fix sometimes? Brad.
              • Willard M.
                • August 31, 1979
                • 422
                By bending, or straightening, the rod you can effect small changes in where you get ground or no-ground in the NSS. For example if that L shaped lever needs to go just a little more to reach a point of no ground when the shift lever is in R, then a slight decrease in the bend will push it further forward to put the NSS in the desired no-ground position. Much of this is trial and error and it helps to have an adult beverage near by to deal with the frustration-much cheaper than a shrink. Bill
                • Brad H.
                  • August 12, 2007
                  • 724
                  Thanks again Bill, I will try some bending or unbending. Brad.
                  • Chris S.
                    • January 1, 2000
                    • 1068
                    you can also loosen the NSS and adjust it
                    for mine - the rod was straight up and the switch was in the middle
                    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
                    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
                    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
                    1957 Corvette - FI 3 sp - Black and Silver
                    • Brad H.
                      • August 12, 2007
                      • 724
                      Chris, Brad here, that worked, all I needed to do on mine was loosen screw toward front and push the nss up all the way on the front end and that did it. thanks both of you for the edjamacation.
                      • Chris S.
                        • January 1, 2000
                        • 1068
                        Welcome !!!!
