69 power Steering center Link relay rod - NCRS Discussion Boards
  • Phillip G.
    • April 30, 1992
    • 42
    Can someone provide me the correct finish on the center link relay rod for a power steering car. ALSO, IS THIS ITEM JUDGED?
    • 15599
    Re: 69 power Steering center Link relay rod
    Last question first -- to the extent that the relay rod (PS or manual) can be seen it will be judged.
    Finish is as forged -- and PS or not makes no difference. There are some colored bands (paint strips around the relay rod). I believe we have detailed this int eh TIM&JG -- as I expect the finish is also detailed there.
    • Ron G.
      • December 1, 1984
      • 865
      Phillip,
      As Terry made mention, the center link relay rod was forged. In regard to the color of the dabs of paint is concerned, my experience has been that P/S cars usually have a blue dab and non P/S cars that I seen mostly have a white dab of paint, but like everything else especially where Corvettes are involved it would not surprise me to see an additional color.
      - Ron
      "SOLID LIFTERS MATTER"
      • Paul O.
        • August 31, 1990
        • 1716
        I also agree with Terry and Ron also the items in the suspension that were forged most had a dark blue to black areas that were from the forging process. This has been seen on many original untouched cars. Here is one example.
        Paul 18046
        • Dick W.
          • 10483
          Gun cold bluing will get you somewhere close.
          Dick Whittington
            • 15599
            [ATTACH=CONFIG]39311[/ATTACH]
            Paul 18046
            Nice photo Paul. There was a long thread a year or so ago in which someone used gun bluing and some other products in an attempt to duplicate the finish -- I think they were working on the rear strut rods IIRC. There were pictures and the end result in the pictures was not too bad. Problem is pictures are a poor substitute for an "in the flesh" viewing.
            • Paul O.
              • August 31, 1990
              • 1716
              Here is a close up of the same area.
              Paul 18046
              • Dick W.
                • 10483
                I believe the dark area is mill scale resulting from hot forging. Frans E(?) could provide a blow by blow description of the manufacturing process, but apparently he is not a member of this forum, and maybe not even NCRS
                Dick Whittington
