Need Help Making a Decision - NCRS Discussion Boards
  • Michael M.
    • June 5, 2011
    • 30
    Newbee here with first post!
    Planning to have my 65 judged. I have the original four hubcaps w/spinner, steel wheels mounted with blackwall radials. I also have four repo. K/O's and goldline striped non-radials.
    Which should I use?
    The original hubcaps have the typical dings.
  • Wes S.
    • May 31, 1982
    • 209
    Re: Need Help Making a Decision
    Remember the tire tub bolts are loner for K/O's, so if you don't change them, you may receive a 100% deduct for the K/O's.
    The wheel covers would probably only get some condition deduction
    • Tom D.
      • September 30, 1981
      • 2151
      I'd use what the car was delivered with. What does the bottom of the jack cover say?
      https://MichiganNCRS.org
      Michigan Chapter
      Tom Dingman
      • Jaime G.
        • April 1, 1988
        • 480
        If you dont know what the car came with, mount the repro goldlines on the steel wheels and hubcaps.
        KO's require not only a longer bolt for the tire tub but the knockoff hammer and the instruction card in the glove box.
        If you dont have those not worth the explainig to the judges. Repro tires are a small deduction as long as they are the correct
        size, mfg. and configuration.
        • Kenneth B.
          • August 31, 1984
          • 2091
          Which should I use?
          I would go with what it was originaly. It seems to me most judges are easier on original parts then repo.
          KEN
