Brake fluid- Silicone vs Standard - NCRS Discussion Boards
  • Douglas G.
    • April 30, 2001
    • 58
    Is there a way of distinguishing which type of fluid (silicone vs standard) is in the system on a used vehicle?
    Thanks for any help. Doug
  • Russ S.
    • April 30, 1982
    • 2163
    Re: Brake fluid- Silicone vs Standard
    Put some oil in a cup. and a few drops of water. The water will come to the top with silicone fluid. Dot 3 or 4 the water will mix.
    • Gene M.
      • April 1, 1985
      • 4233
      Doug,
      Most of the silicone DOT 5 stuff is purple.
      • Russ S.
        • April 30, 1982
        • 2163
        Originally posted by Gene Manno (8571)
        Doug,
        True Gene but only when it is new. It changes color with use.
        • Gene M.
          • April 1, 1985
          • 4233
          That is true Russ, but takes a few years, hope he didn't let it go that long..........
