Steel Vacuum tube on firewall - NCRS Discussion Boards
  • Tom L.
    • October 17, 2006
    • 1439
    Last nuight I was cleaning some rust off the vacuum tubes that run along the fire wall on my '72. While cleaning I noticed a small hole in the tube. Any ideas how to repair and refinish the tube?? The rust has taken over almost 50% of the surface. I'm pretty sure the tube is not reproduced so I think I'm stuck with this one unless I find an original in good shape. Thanks!!
  • Paul O.
    • August 31, 1990
    • 1716
    Re: Steel Vacuum tube on firewall
    Lynn
    If the hole is not very large you maybe able to have it brazed closed.
    Paul 18046
    • Larry M.
      • January 1, 1992
      • 2695
      Lynn:
      Buy some tubing and a tubing bender and make your own vacuum line.
      I would check with a few suppliers like Ecklers, Keen Parts, Zip, etc and see if they carry/sell them. You can also contact Classic Auto Tube or Inline Tube and they will make you one from your old line.....they may even have a computer scan templet in-house by now. Don't know what their cost will be for this service. Probably not too bad, since they get to keep the templet, and fabricate/sell other lines from your example. Google the names for phone numbers and websites, or let me know and I will provide.
      Larry
      • Tom L.
        • October 17, 2006
        • 1439
        The hole is probably not more that 1/16". I can braze it closed but the finish will be worse off when done. Any suggestions on a finish for it, and the rest of the lines?? They don't look great now and I'd like to pretty them up before I put them back in. Thanks.
        • Tom L.
          • October 17, 2006
          • 1439
          Did think of that but there are two lines brazed to each other. If I get two lines made and braze them together I'll be in a similar situation.
          • Jim T.
            • March 1, 1993
            • 5351
            Curious, what are the functions of the two lines brazed together?
            • Tom L.
              • October 17, 2006
              • 1439
              This is from memory so it may be incorrect. One line is the vacuum supply to the wiper door relay mounted on the fender and a smaller line connects to the vacuum switch under the wiper door. Hope I got that right.
                • 6942
                Lynn, can the steel tube be made from a piece of tubing careful bending and a couple of extra hands to hold the tubes as you bend. I do this all the time at my automotive shop when replacing brake and fuel lines.
                • Tom L.
                  • October 17, 2006
                  • 1439
                  To make a functional set, yes. However to make a set resembling the originals your method will likely kink the lines, there are several tight bends.
                    • 6942
                    JB Weld?(epoxy)
