Re: Weights on outside of wheels
I doubt if alignment is the issue. Did this problem start after the new tires were installed? What's the make, model and size of the tires?
Can you estimate the frequency of the vibration, and do you have a sense where it is coming from? Is the vibration frequency constant or does it vary with speed. At what speed does it start and stop.
You said it only occurs under heavy acceleration in first gear, and I assume it's a manual transmission. Describe what happens as if we are watching a movie - every possible detail.
The better you can characterize the problem the better the diaganosis can be.
!! I know that my smile could be ear-to-ear if I could figure this thing out
. When I look at the front end components, the rubber bushings look "tired" to me (old and showing some small cracks). However, a few mechanics have all told me that everything was tight and wasn't worn to the point of needing replacement. I attached a few photos from my pre-purchase inspection a few years ago. Anyone coming down to South Florida for a vacation this year??
