Rebuild original carb - NCRS Discussion Boards
  • Bob W.
    • August 31, 1981
    • 84
    I was going to send my carb to Paragon to be rebuilt, has anyone had any experience with them? Since it is an original carb, I didn't want to undertake the task since I have never rebuilt a carb and didn't want to take the chance of messing up.
  • Philip P.
    • February 28, 2011
    • 558
    Re: Rebuild original carb
    There are some rebuilders advertise in Driveline. The Carter WCFB is not that bad to rebuild if you have some mechanical skills. The passenger car manual, 1958 anyway, has a pretty good section on rebuilding and there is a pdf manual on line somewhere I will try to find it, I do have a copy if you are interested.
    Phil
    • John F.
      • March 23, 2008
      • 2418
      Bob Kunz is the best. Rebuilt/recolored mine. Put it on, a little gas, and fired right up and idled as it should. (314)845-2566
      • Nicholas L.
        • November 1, 1982
        • 342
        Bob Kunz's work is top notch.
        • Joe M.
          • April 30, 1990
          • 1342
          Do you want show quality rebuild and recoloring or just clean up and rebuild. The cost between the 2 options is significant.
          • Bob W.
            • August 31, 1981
            • 84
            Don't need show quality
            • Dana M.
              • January 1, 1999
              • 34
              Have used ALL American Carburetors several times. Look like new and run great out of the box.
