1959 judging issue - NCRS Discussion Boards
1959 judging issue
  • Gary L.
    • June 19, 2011
    • 62
    1959 judging issue
    Had a judge at nationals note that the tie rod to drag link sleeve bolts were too long and should be "tr"" designation. The bolts do need to be 1/4 shorter, but these are "ur" designated bolts. Does anyone have correct bolts designation? They should be grade 5 fine thread 5/16 bolts with lock nuts the best i can tell. Not sure if he meant "ur", which paragon shows for this application, or should they be "tr" designation. This will be a simple fix soon as can obtain correct ones.
    • 15606
    Re: 1959 judging issue
    Gary,
    I will give you a free ride to the top.
    I can not tell you anything much about 1959s -- BUT I can tell you that almost never is there only one head mark applicable to a specific position on a Corvette. As you know the head mark indicated not only the grade of the fastener, but also the supplier. For what seems like a common bolt like this, I would expect several head marks might be appropriate. Hopefully someone with an intimate knowledge of the 1959 chassis will be able to help.
    Meantime enjoy the ride.
    • William D.
      • November 14, 2011
      • 10
      Gary, currently doing frame on restoration on C-1. Am original owner and some what an accomplished mechanic. Have an original tie rod sleeve bolt in my hand. This bolt is actually 1-1/8 " long with an L mark on head. We have replacements from Zip and they are 1-1/4" long with UR head mark. Corvette Central indicates a TR head mark, but just checked their web pic, it is UR head mark. Ahhh, the repro market is great. Obviously, I'm using whats available.
      • Mike M.
        • May 31, 1974
        • 8396
        both of my 57's had "L" mfgr logo on these bolts. mike
        • Gary C.
          Administrator
          • October 1, 1982
          • 17736
          Gary,
          Richard Brodeur who posts here IIRC did an inventory of '59 bolt head markings.
          As Terry said most applications might have used more than 1 bolt manufacturer (head marking).
          Most of the original tie rod adjustment bolts I've seen had L head markings.
          The vendors seem to follow the "general rule" that suspension bolts head marks were typically TR with some UR thrown in.
          The 56-7 Judging Manual 5th edition revision team spent a lot of time trying to compile the different bolt head marks and where used.
          JMTCW,
          Gary
          NCRS Texas Chapter
          https://www.ncrstexas.org/
          • Gary L.
            • June 19, 2011
            • 62
            Nothing in 58-59 judging manual about trademarks or length. 1 1/8 inches looks to be the correct. I have the "ur" trademard that are 1 1/4 long. Both trademark and length are in question.
            • Bob M.
              • March 1, 2004
              • 66
              Gary,
              I have TR bolts on my 60, they look like they have never been replaced. Also, look like they are in the 1 1/8" range.
              Bob
              • Gary L.
                • June 19, 2011
                • 62
                Are they cadium plated or dark like gun metal grey?
                • Bob M.
                  • March 1, 2004
                  • 66
                  I can't say for sure because of the rust issue. I wire brushed the tie rods, fastners and put a coat of clear lacquer over everything after I put the inspection marks on.
