Antifreeze leak on 61 - NCRS Discussion Boards
    • June 21, 2010
    • 17
    I have an antifreeze leak between the front engine mount crossbrace and the block on my 1961 Corvette. According to my service guide there should be a gasket or gaskets between the crossbrace and the block but I don't find them in my parts books. Do I use 4 water pump gaskets two under the crossbrace and two under the water pump or is there special gasket for the block to crossbrace joint? Thanks for the help.
  • Charlie P.
    • July 31, 2003
    • 260
    Re: Antifreeze leak on 61
    I used four of the same standard water pump gaskets, one on each side of the crossbrace of course. Seems to be fine.
    • Mike E.
      • February 28, 1975
      • 5141
      When you have it apart, check the integrity of the cross race. They often are rust-pitted, and leaking results. Also, it's difficult to get the brace and all four gaskets lined up to go back together--cut the heads off a couple of extra 3/8 bolts , use them as guide pins, and then when you have two regular bolts in and securing it all, remove the guide pins and replace with correct bolts.
      • John F.
        • March 23, 2008
        • 2415
        You also need to jack the motor a little to take the tension off the mount when removing the water pump. Build a little cradle with a 2x6.
        • John F.
          • March 23, 2008
          • 2415
          Oops! Forgot the picture of the cradle.
          • Bruce B.
            • May 31, 1996
            • 2930
            When replacing the gaskets coat all surfaces with Permatex #2 and tighten per specs.
            Do not use silicone sealer or you will have to repeat the job.
              • June 21, 2010
              • 17
              Thanks everyone for your insites this doesn't look too difficult, just a lot of stuff to unhook and hook back up.
                • June 21, 2010
                • 17
                John, I am not sure how to place this cradle. I assume it would support the oil pan to block flange at the front of the engine with open end facing the rear of the car?
                • Bruce B.
                  • May 31, 1996
                  • 2930
                  Correct, That is how the brace works.
                  Bruce B
