C3 ingition accessory position failure - NCRS Discussion Boards
  • Hank H.
    • July 31, 2006
    • 76
    Gentlemen, in going through the PV manual for an anticipated test on a 72 T&T equiped car, I find that I have no power for radio and windows in the accessory (first) position of ignition switch. I have a working key buzzer in this position however which by the way was replaced a couple of years ago. Any ideas on cause of this situation? thanks
    • 6960
    Re: C3 ingition accessory position failure
    Hank, the ignition switch under the steering column is on a slot and can be moved some, its in a bear of a spot I believe the bolts that attach the switch to column are 5/16 heads and there are two of them.
      • 15640
      I believe the windows do not work in the accessory position, but check with Stan to be sure. If memory serves that is an error in the manual. However, the radio definitely should work in the ACC position.
      Perhaps someone else with a PW early C3 can verify my recollection. It has been quite a while since I did a PV.
      • Ralph S.
        • February 1, 1985
        • 935
        Power windows do not work in acc. position
        • Pat M.
          • April 1, 2006
          • 1588
          I believe Terry and Ralph are correct, power windows should not work in the ACC position.
