New to corvette and especially to 2 x 4's and dual point set up w/o vacuum. I get a popping back through the carbs on moderate accel and do not feel carbs are adjusted right and the "feel good method" of turning screws not getting job done properly. I have a '61 270 hp and My question ( and I searched past threads w/o any finds) is how to use vacuum guage to adjust carbs. More in particular, do you use a tee fitting and draw vacuum off both carbs at same time while adjusting screws per the manual or do you do each carb vacuum one at a time. Also I assume I get vacuum at rear base of carb with a nipple type fitting. any help will be appreciated. As a side note there is a loud ticking noise coming from rear carb at the vent bowl cap. any idea what can cause this before I take carb apart??? Thanks, Mike 53700
