62 speedometer needle bouncing then going to the high side - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2415
    Pulled the cable out and it doesn't look chewed up. This car sat for 20 years in a garage up on blocks. Can I disconnect the cable at the tranny end and sparay some cleaner such as WD-40 and put air to it and blow it out toward the tranny. Then lubricate it!
  • Joe R.
    • July 31, 1976
    • 4551
    Re: 62 speedometer needle bouncing then going to the high side
    John,
    You would be best served by purchasing a NEW cable and replacing the old one IF that is your problem! WD-40 and lubricant is the road to disaster!
    JR
    • Mike E.
      • February 28, 1975
      • 5141
      John,
      the problem more often is that the actual speedometer head itself is lacking lubricant/dried out. There's an article in an old Restorer on how to lube the speedo head.
      • John F.
        • March 23, 2008
        • 2415
        Mike, Could I get a copy of that article somehow? Is cluster removal required? This is a Bowtie candidate and I wonder if I can mess with it prior to judging.
        • Vinnie P.
          Editor NCRS Restorer Magazine
          • May 31, 1990
          • 1573
          John...check your email
          • Philip P.
            • February 28, 2011
            • 558
            I used some lubricant called cable ez seem to work, cleaned the cable and then added the lubricant, I was reccommended by someone here.
            My speedometer would "catch" I guess that is how to describe it.
            Phil
            • Peter V.
              • June 2, 2008
              • 116
              John,
              My early '61 had the exact same problem.
              Lubricant and tranny fluid had worked its way up into the speedo head. You may have to pull the gauge cluster to fix it.
              Find the source of the fluid and/or lubricant - once you stop it, things should be fine. The cable could be just fine.
              Peter
              • Bruce B.
                • May 31, 1996
                • 2930
                John,
                Same problem on a 62 a few years back.
                Pull the cluster out , otherwise if you hook it up and drive it you will ruin the speedo mechanism.
